1 - 9 of 9 Posts
Bent a valve on my klx stock head, so thinking of putting a big valve head on before i sort out a bore kit.
will the pitster head work without changing the reliefs on my stock piston?
cos this seems like a cheap race head option.
plus will it work on a tb165? cos thats the bore kit i will be going for.
thanks
the YX 150/160 heads will NOT work without valve reliefs. i have one on a TB143 rh piston kit and it runs really good for a cheap top end.. these heads make a lot of ticking noise though, i thought something was wrong with mine, but ive read from a few people on here and their YX heads do the same thing..
get the 165 scut and a FPM ported YX150/160 head. for the price, it should be a really great set up. then later you can upgrade to the TB V2 roller rocker head ;)
Vendor
"Pitster Head" should be better defined.
YX 150/160cc stock head KLX type:
Accepts Stock KLX cam covers and is made with 2 different port types
A Port type will accept CRF Pipes
B Port type will accept KLX Pipes
ZS 155 stock heads DONT accept stock KLX110 cam covers
and all accept KLX 110 Pipes.
All these heads will work fine on TB kits.
Check valve to piston clearances when running on a stock 110.
More tech data on heads here:
TBolt USA, LLC
Vendor
slayerklx said:
thanks T-bolt.
Does anyone make any s-cut 160 kits as our class limit over here is 160 and i cant be assed to bore my cases
Easy,
Run a TB 143cc / 60mm kit with TB Stroker crank for 155cc
Bolt on and go, Plus you have the longer skirted piston.
1 - 9 of 9 Posts
