1 - 1 of 1 Posts
I am having some sort of issue with the front brake on a pitster setup. What initially happened was while riding a stick got wedged between the pad and caliper. This locked up the brake, it was a mother f'er to get the caliper off, finally did, took the stick out. At this point the pistons were pushed out far enough that the rotor wouldnt fit in between the pads. So I sqeezed the pistons down like I would with a car caliper. After that I had no brake, I have bleed the system every way I know how, and can not get any front brake. Does anyone have a clue what happened? Did I break something by compressing the pistons? Did I torch a seal from riding from the track to the pits with a semi locked up front wheel?
1 - 1 of 1 Posts
