1 - 6 of 6 Posts
Picked up the 140 and the matching Piranha exhaust. And bought a real Mikuni vm24 off a kx65. Any ideas on a starting point for jetting? I tried searching but everything I am seeing is for the vm22 or vm26. This will be on an ATC70.
Discussion Starter #3
The carb did come off a 2stroke engine. But it is not a 2stroke specific carb.
Discussion Starter #5
From another form the guy recommends:
95-98 main
37 pilot
2nd clip from the top on needle
1.25 turns out on air screen
If it's the VM24-512 series, you should start with a 25 pilot and a 170 main. If its some other version, no clue. As an aside, the needle jet, jet needle are usually different on 2 stroke vs 4 stroke carbs.
1 - 6 of 6 Posts
