1 - 4 of 4 Posts
What do you guys run in your forks? 10wt or 15wt? About how much goes in? my forks are pretty mushy right now, i got damping rods and springs in them and just reused the stock oil when i did it. i would like to change it and have it a little more stiffer. Is it hard to just change the oil?
Most people run 20wt and its not too hard to change the oil, just take off the cap, pour out the old oil, take out the spring, compress the forks all the way down, fill oil till it is 90mm from the top, uncompress the forks, put the spring in and the cap back on and you should be done!
Hope this helps!
1 - 4 of 4 Posts
