1 - 7 of 7 Posts
Oil leaking from engine breather
I have an 06 110 that ended up sitting for a year or so. The last time we rode it there were no problems, at all.
We pulled it out the other day to ride and oil is now seeping out of the engine breather tube on top of the motor. I have NO idea what is causing this.
The bike is totally stock, other than a pod filter and PC pipe.
Anyone have any ideas? Please help
are rare possibility is that the gas was left on, the float was stuck, the intake valve was cracked open, the crank case filled with gas over flowing out the breather. Its happened.
its heat build up and crankcase pressure, syphoning effect from the vent hose and overfilled crankcase also does it.
1 - 7 of 7 Posts
