1 - 3 of 3 Posts
i ordered the staggs cooler. problem with the staggs cooler is the bracket is not long enough. there is a tapped mount on the underside of the frame tho. so i reshaped the supplied bracket, drilled a larger hole in it, and used a 8mm bolt. but while installing the cooler line i over tightened a fitting and broke it, they shipped a new line from staggs today. so once i get the new line i will mount the cooler back up a take a pic if ya want. ok later
1 - 3 of 3 Posts
