alright so im going to either be running a 146 kit and a lifan bv head on my gpx or just a 146 kit. is a oil cooler an absolute must for both situations?
londregmoto said:alright. hey trailpimp what kinda coolers did you use on your x4 to mount them in between the shroud and tank/frame? and how much work did it take because i would like to mount my cooler the same way on my 50
There is a piece of carbon fiber (you could use steel or aluminum) from the tapped hole on the bottom of the frame tube to the cooler, then a support piece from the shroud tab on the tank. Pretty easy, you just need to make sure that the fork clamps don't hit it.londregmoto said:how did you mount it on that bike?
