1 - 7 of 7 Posts
Premium Member
tocute4urpantz said:
Let me just say this, I have never seen an engine be damaged after an installation of an oil cooler (after long run periods, entire seasons) which was a direct result of a lack of oil to a certain point in the engine because of the installed oil cooler. I have seen our engines run on the Dyno at Boyesen's with an infrared gun showing decreases in temperature after the installation of the TB cooler mentioned in that thread.
"I understand the thinking of most that a cooler holds more oil so there fore should cool the fluid, but unless you can keep pressure stable through out the entire oiling system, you are going to create cavitation and impead oil flow.
Hence part of the reason why coolers don't work in a CRF50 based engine." -Dood
read what dood has to say in the threads he has some quality info.
1 - 7 of 7 Posts
