OK-- So I told ya I'd get busy on the front mounts for the RS/NSF250 tail section I'm running. It seems like it'd be easy enough, but the ubdertail exhuast complicates things a bit. I decided to have John fab up some flat plates and weld them into the V-shaped subframe area. Not only did this provide a location to add "bosses" to attach the front ears of the tail, but it adds some additional rigidity to the frame in the event of a crash.
I don't know if you can tell from the pics I posted, but the plates have a crease in the middle so they will meet with the top rails, as the top and bottom rails aren't parallel. The mounts came out great, and as always, the tail fits perfectly.
With this-- the subframe is finished with the exception of a couple small braces I want welded on the back, and I was going to use a hole saw to take out some material in the plates we welded on to save a slight amount of weight, and to enhance the looks. You won't see them anyway as the tail will be hiding the handywork. It'll need bead blasted, and I'll bolt it together and post some pics.
