1 - 8 of 8 Posts
I got the bike back from the shop friday. They put a TB88 stock head kit on it. I drove it all day yesterday, rode the bike for a few hours today, killed it, and now it won't start.
I searched all the old posts to try and find out the problem but no luck on any fixes.
I couldn't find any loose wires.
I changed the rev box
I put new gas in it
I tapped the carb in case the floats were stuck?
I took apart the kill switch and everything seemed to be on there right
Key is in the on position, tried the gas valve in the on and reserve position
If I barely hold the throttle, it will run for a few seconds then just die. It has good spark, getting gas, and good compression. I have no idea what the hell the problem is. It was running great earlier today and starting 1st/2nd kick.
Discussion Starter · #2 ·
Oh and I put stunt pegs on it right before it started acting up but that couldn't have caused the problem right?
Discussion Starter · #4 ·
i believe so. the guy that did it put it through a few heat cycles and told me just not to peg it out or rev it all the way up to the rev limiter and just ride normally, so that is what i did for some 15-30 minute cycles.
Discussion Starter · #8 ·
it turned out it was that the float WAS sticking. took it apart, messed with it, and it runs like a champ.
1 - 8 of 8 Posts
