G
Guest
·If someone can help me with the order I will write up a HOW TO DOCUMENT with pictures so it will make it easier on the next person
Here is what I did
1st = I removed all the stock clutch parts and gears
2nd = I installed the large gear next to #11
3rd = I installed the #11 on the back of #12
Question?
Under #13 I installed #10 first, #9, then the lock nut
Then I bent the tab onto the lock nut
On top of #13 I installed #7, put #6 inside #7, and then #5(spring)
If I have installed all of the correctly, where does #9 GO????????
Does it go behind #11(small gear in the picture)?
Thanks
[/img]
Here is what I did
Question?
Thanks
