1 - 8 of 8 Posts
Hey fellas!
I am changing my head (finally got an Ultra) and intake manifold (larger port) and where the throttle cable goes into carb it seems to hit the frame.
I've got the 20mm carb from Classic & also using the black heat shield spacer. I was going to toss the spacer (more torque maybe?) anyways, but I think I will need to slightly bend the metal tube/guide that flows into top of carb.
Apparently this most be a common issue, because my buddy who just bought a new frame has the exact same problem, maybe just a little worse.
It is hitting the frame main tube, NOT the tank.
Hope you guys can help.
Later!
JD
Is the actual top metal peice hitting or the rubber boot? :?:
Discussion Starter · #3 ·
The little copper tube that screws into carb cap it hitting bad.
The carb will fit in without cap, but with cap in/on it is about 1/4" from being able to match up the mount holes on the carb to intake manifold.
I think with removing my plastic heatshield/spacer & a little "convincing" I can get mine to work.
BUT, my friend has already removed the spacer & his still hits!
I need to fix it before Sat. night, dying to go racin' @ Hardrock.
What exactly does the spacer do? I just set up my carb and I just threw it on and mine fits, lucky me I guess :lol:
Where do you live? Florida Im assuming, but where at?
Discussion Starter · #5 ·
Do you have stock head & frame?
I have an Ultra head (slightly different shape) & alum. BBR frame (fatter).
I think both of those contribute to my problem.
I live in Gainesville, Florida.
i had the same problem with my stock carb and stock frame, the metal leader on the throttle cable was hitting the frame, i bent the metal down a bit to fix it
Ive got a different head but stock frame, are you racing Pax?
Discussion Starter · #8 ·
Nope,
Out of town on Feb.7 & for the Daytona Supercross:
I was when it was sched on the Friday night, but now I will not be in town that Sat. night.
1 - 8 of 8 Posts
