Are you installing the throttle slide into the carb throat with the beveled edge of the slide to the back (airbox) end of the carb? Also, make sure the air screw is backed out 1.5 turns from seated, and the idle adjust screw is out quite a ways, until you can get it to stop revving up when you touch the throttle.
