1 - 3 of 3 Posts
Can I use any aftermarket heads, pistons, or cylinders on a cr107 motor? Also, can I use any aftermarket carb?
G
yes Classic makes a 54mm piston kit for the cr107 and you should run a 24mm carb to get the power you want
If you need help we can get it for you
Discussion Starter · #3 ·
Cool, thanks. I just wanted to know because i'll probably be buying a 107 from a friend for $500. Are the cases pre-bored to 54mm? I was planning on using the 24mm flat-slide carb, it seems like it would be a good match.
1 - 3 of 3 Posts
