1 - 3 of 3 Posts
So i just got this bike off a guy for extremely cheap, and it needed some work, but like i said it was reeeallllly cheap. i'm having a slight problem with the motor, when i put it into neutral, and then kick it over, sometimes it goes into gear, i took the flywheel cover off and there's a tiny bit of rust, and when i took the oil filler cover off the oil was like up to the top, any ideas?
You have 2 different issues my friend.
Your oil level was prolly a result of a stuck float valve and filled the engine with a gas oil mix.
Your shift/starting issue is prolly a rounded out shift star or weak detent spring.
1 - 3 of 3 Posts
