1 - 3 of 3 Posts
hi i have a motor as below
tb 88 kit and tb head, and a tb manual clutch, shaved flywheel.
i am thinking of adding a crank and close ratio gear kit, but what crank will work with the cylinder and head i have allready (tb). i have only seen them in kits with a cylinder and i dont need another one!!
what are your recomendations, and would it be better with my shaved flywheel or a inner rotor.
help me please
Kitaco 51mm stroker crank, Kitaco stroker piston - contact sik50's for pricing. You will be able to use your 52mm cylinder and head. You will also need to move up to a 24mm carb, Keihin PE24.
Keep your shaved flywheel with the stroker crank.
The Inner Rotor will work to Its just kind of costly Make sure you get the Round Slide 24mm carbs the flat slides are hard to tune. the close ratio tranny upgrade is an excellant choice it works Primo..... :twisted:
1 - 3 of 3 Posts
