It's a stock bore xr50 with ported and larger valves head. When I put it together everything is right, but it revs up slow not as responsive as it was stock. Do you think the stock carb is to small? if so what would be recomended? Maybe the 17mm???
yesDRTracing said:do you think if I up the compression it will help?
DRTracing said:This head was ported for a stock motor so I was told. but I have not been able to make it run right . I tried jetting, carbs,pipes that's why I was asking about the compression.power-roll has a 13to 1 kit what is stock? If this does not work right im going back to stock and trow that head in the trash. I think it should as fast as stock not slower like now.
