1 - 6 of 6 Posts
Just bought a used magura hydro clutch kit from a the classifieds section. After starting the install , going off the 2 bros install instructions I realize I didnt get the "thrust washer" for the shift shaft end. So Does any body listening happen to have this "thrust washer" and some calipers , can you measure how thick it is and the outside dia. and a guess as to what it is made of- ie: steel , brass , bronze etc. Any input would be great help. Thanks.
Discussion Starter · #4 ·
Kind of what I suspected. There is nothing to thrust against except the splines on the shaft. Kind of silly that is one of the things highlighted in BOLD in the 2 bros. Instructions. Thanks again.
1 - 6 of 6 Posts
