1 - 11 of 11 Posts
My lifan motor (only 4 rides on it) seems to vibrate quite a lot. The engine also has a slight clicking sound.
I have checked the clearances and all the bolts on the bike.
Should i worry or leave it???
it is a lifan 1st - neutral - 2nd - 3rd - 4th
Thanks
yeah, even with awesomely adjusted valves, they will always click. your probably hearing a lot of it out the air filter.
as for the shaking, the motor is bolted directly to the frame on these bikes. there are no engine mounts like in a car, where they damp the vibrations.
have you had other knockoffs that dont shake like this??
Banned
i am going to say its the oil slinger, my gpx was doing it, and it was just a loose oil slinger nut. i tightened it up, and now im all set. definatley check it out, (you need to take the oil slinger plate off to see if its loose), the plate has 4 philips head screws and can be kinda tricky to get loose with out stripping it, id use a impact screwdriver, the kind you hit with a hammer to break the screw free/loose.
-dave
1 - 11 of 11 Posts
