Seeing as I've got a dead Lifan 141 setup... and there's always room for bench build chats...
Plot the ultimate Lifan 141 build!
Clutch/Tranny Improvements:
- Thumpstar revised 3rd and 4th gear (Closer ratio setup, doesn't help 1st though.)
- SDG shift fix kit
- TRX90 clutch basket (Direct bolt on?)
- Aftermarket alu/kevlar clutch plate set
- TRX90 clutch springs
- Ceramic bearings?
Bottom End:
- Xtreme oil sling (Makes shaved alu units look heavy.
- Crank lightened, trued, polished and balanced for 11k RPM
- Ceramic bearings?
Top End:
- Nikasil line cylinder
- make full use of performance coatings on piston, head and cam
- Ti valve set
- lighten and polish rockers
- Ti tappet adjuster nuts
- Port and polish head
- SDG shift fix kit
- Ceramic bearings?
Bottom End:
- Ceramic bearings?
Top End:
- Ti valve set
