1 - 3 of 3 Posts
Sup fellas i recently bought a lifan zxtdr150cc oil cooled motor and i have a couple questions aboot it. The first being an oil cooler. It did not come with one so i ask is it absolutely required that i have one or does the oil pump do a sufficient job at circulating\cooling the engine by itself? Second....where would be the more ideal spot to install one if i do infact need one? The ports on the crank case or should i install it on the piston head? Can i get crazy and come up with a way to incorporate both of them? Any info would be greatly appreciated
Welcome to planetminis
You definitely need to run an oil cooler
Given things are going to get very hot it’s good to keep your engine cool
1 - 3 of 3 Posts
