1 - 10 of 10 Posts
The shifter shaft is too short so I can't use a regular 50 shifter without it hitting the bottom of the ignition cover. Would a 110 shifter work? Cause they seem to come out then up. Are they the same size?
I have wondered if a 110 shifter would work. I have a shifter for it if you need it. It's nothing fancy. Just a chrome shifter.
I believe I put a shift shaft from a TB manual clutch in mine. That would explain why I can't find it right now. I am pretty sure that is what I did b/c I have been running a Classic Honda shifter on it.
Discussion Starter · #3 ·
Cause on the 110 shifters they come out and then up. So I was wondering if they did. I really could use one. How much for yours?
Also I need some help with the electronics. I have a crf70 on-off switch that needs to be connected.
Send me your address and I will ship it out on Monday free of charge. I hate to see you not able to ride.
There are usually a couple of those cheap aluminum ones on Ebay for sale but they are crap. I say put in a tb shift shaft and be done w/ it. That way you can run the shifter you want.
1 - 10 of 10 Posts
