I would like to run the Kx65 front wheel and hub\brake setup on my GPX forks for my KLX 110. Is it possible to make them work relitively easy? I see the Adapter for the CR85 caliper but would like to run the whole 65 setup.
You would have to figure out other bearings that would except the bigger 15mm axle. The CR85 caliper works just as good if not better then the KX65 brake due to the fact that the rotor is a 220mm on the pitster LXR forks. And I would get the YZ250f/YZ450f Master cylinder not the KX65 cause the YZ stuff has such good feel in comparison.
