1 - 6 of 6 Posts
they will not, i reapeat WILL NOT BOLT ON, modification is needed, first and foremost the width of the 110 frame is 5", the space in between the two mounting points on the 60 swinger is only 4". So if your gonna do this you are going to need to either have the swinger cut and rewelded or weld brackets to the frame of the 110 that are 4" appart and then put the 60 swinger on.... the prob with this is that it is going to put the swinger even further away and I dont know where you are planning on mounting the shock on the swingarm, the stock 60 shock dosent mount to the swingarm, it has some crazy linkage set up. Good Luck.
1 - 6 of 6 Posts
