1 - 12 of 12 Posts
[quote name='mutinytattoo']of an 05 or 06 i cant remember for sure which one,, i have the stock spacers, for it,,[/QUOTE\
Will the stocks work with a KLX110?
Discussion Starter · #5 ·
yes, this will work on a klx,, you will just have to make sure the spacing is right for the chain,,, at most you would have to mess with grinding the spacer down a lil, or ad a washer to move it left or right to make sure the chain is lined up correctly
Discussion Starter · #12 ·
fasterthanyou said:
Still got it?
yes i still got it,,, ive measured this setup to a 110 swinger,, its will work just fine, you only have to adjust the spacing to make sure the sprocket is lined up
1 - 12 of 12 Posts
