1 - 6 of 6 Posts
10mm banjo bolt? Actually it's not Brembo, caliper is made by Formula.
02'-03' 65SX's used a Brembo master cylinder and Formula caliper with 10mm banjos . Later years used a Formula master and Formula caliper, but with 8mm banjo bolts. The 10mm is the one to have, since it will work with virtually any master cylinder without needing a custom line.
Discussion Starter · #4 ·
OK, Thanks!
1 - 6 of 6 Posts
