1 - 3 of 3 Posts
I have 03 klx 110 with a 04 ktm 65 swing arm and shock. the bike sits up high when nobody is on it but when you sit on it goes down pretty far to a good ride height. i was able to do this by adjusting the shock but is too soft when you start to ride it hard and when you go over something that makes the suspension spring up like the whoops the chain sometimes slips. i was thinking to fix this i would have to get a shorter shock with a stiffer spring or make mine shorter. the ktm shock works well otherwise.
you could just put some taller forlks on to make it sit leval. then you could stiffen the shock. How did you mount the swingarm?
Discussion Starter · #3 ·
i bought it with the swing arm and it looks like it just bolts up because it looks like theres nothing changed from a stock ktm 65 with the same swing arm.
1 - 3 of 3 Posts
