I know I have seen them, but I cannot find one. I need a frame bracket which clamps to the frame, but allows me to bolt a kx65 master cylinder to it, to use rear disc brakes. Anyone?
I'm pretty sure if you get a tab welded onto your stock 110 swinger (like the tab on aftermarket swingarms) then you can run the str A-frame style adapter for the 65 brakes.
Oh and str has the brackets for the frame/master... siktendenciesracing.com or pm Gary
Post this in the siktendencies vendor forum and Gary will see it.
Or make a thread in the classifieds wanted section for the str kx65 rear master bracket/mount for the frame. You don't see them for sale used too often though, especially just the frame bracket by itself. Good luck
