So I Bought a 2007 Klx110 with a broken output shaft. The motor it’s self is “good” but I want to freshen it up wile I have the case split. And ideas on What else should I be looking for and what should I just replace wile I’m in there?
Thank any info will help!
Plan on doing the 4speed drum also wile it’s apart
Thanks! As for the crank I’m not going for a race bike lol but when I pull it apart and if the crank needs to be replaced I will do that but as for now I’m going to keep it stock or just do a 143 bore kit with stock head
I did the 143 big bore kit, a 55mm crank, 26mm carburetor and a 4 speed shift drum with my stock head and it performed great. It was an awesome upgrade for the little bike. I did drill out the inside of my exhaust to let it breath better.
