1 - 4 of 4 Posts
I got a 2005 klx 110. Has 143 big bore kit and Mikuni vm26 carb. Bike will fire up and run but as soon as I start Riding it it will bog and die with in 2 minutes. I’ve replaced the carb, replaced the petcock and can see gas getting to the carb. Any help would be great.
Belive it or not I had the same issue, but mine lasted 30 minutes. There is a lean out screw on the front right side of the carb. Turn that screw out and see if it does it anymore.
1 - 4 of 4 Posts
