The 20mm ShengWay carb is relatively easy to tune right out of the box. It comes with the #89 main and a #35 pilot jet, both of which you can buy the extra jets from TrailBikes or any TB sales rep. As a baseline setting, I use the #90 or #92 main jet, the #38 or #40 pilot jet, set the jet needle at the 3rd or 4th notch from the top, and the air screw at 1-1/2 to 1-3/4 turns OUT from seated. Make the necessary air screw adjustments IN to richen it a 1/4-turn at a time and see what the bike does. With some of the carbs, I've run it to within a 1/2-turn of being all the way IN to get rid of 98% of the off-idle hesitation. You might have to raise or lower the clip on the needle, depending upon your altitude, I'm at sea level.
