sounds like its set too loose...try to tighten it down on the spring and then with a aspanner wrench tighten it down........get it so that its a few turns from initial contact with the spring.......that way the spring acts as a lock washer and holds it from turning itself loose.......if that doesnt work then something is wrong with it.
if after that doesnt work talk to mxishock or shiftwideopen. or just give them a call. www.mxishock.com
