1 - 12 of 12 Posts
Is there a carb setting up guide anywhere??
I think I new to adjust something if I go from fully closed throttle to fully open it spulters abit.
Stock engine with TwinAir filter and sano pipe
If not what does each screw do on a stock carb?
next week ill be writing a full carb tuning, but in short thy turning the air screw(the highest up is the idle, then the air, then the empty)in slow(quarter turns) then drop it w/o util you see a change, then go from there.
In the August 2003 issue of motocross action there is a really good guide to jetting, but if my digi cam was working i would take some pics for you.
and btw, there is no air screw on 4 strokes, its called a fuel screw
Discussion Starter · #10 ·
I still havent done it yet havent had the time. I had a quick go around the local BMX track and found myself coming short on loads of jumps that I normally clear because it was spultering on full chat on the take off :( So I really need to sort it out.
Its just I dont want to make is worse.
1 - 12 of 12 Posts
