Have any of you seen or done this mod? It was originally submitted by "Blairjw" on another forum. Just curious as to what your opinions are before I crack open my 50.
--------- Original thread --------------------
Alright, I had to test this, and last night was the first race since I did this and I wanted to make sure it made a difference before I posted... hopefully nobody I race with reads this... This is for a 2004 CRF 50 I am not sure if how far back the ignition goes, your milage may vary.
First remove the cover over the flywheel, left hand side.
At about 4 oclock, there is the ignition pickup sensor, remove the 2 8mm screws and let it dangle...
There is a spacer behind it... remove. The little block on the flywheel is large enough to catch the sensor with or without that spacer, save a little weight here...
NOW HERES THE IMPORTANT STUFF READ IT CAREFULLY
Now get out your dremel tool and egg the holes in the pickup unit about 2-3 mm towards the top... leave the bottom surface of the holes untouched.
When you reassemble, set the pickup down, so the screws are seating in the new area that you have slotted. What you have done is advance the timing a couple of degrees.
Rotate the flywheel be hand counter clockwise after you have attached the pickup unit to make sure there is no interference with the block on the flywheel with the pickup unit.
Replace the cover and try it out.
I don't have any pre-detonation, but I am running 105 octane VP fuel.
This mod allowed me to get the holeshot last night everytime... even with stock exaust. my only other mods are the joker choke removal, and a uni filter, lifting the carb needle and setting up the carb air screw correctly. I was pulling away from bikes with aftermarket pipes.
Next time I get a free minute, I will slot the holes a little more and put a timing light on it, so see the actual advance.
