What should i go with im 165.
dirttrackin280h said:I'm 190lbs.
I just receive an I-shock M1-A4 today and installed it. It has the Standard spring. I have not ridden it yet since I just installed it, but just by sitting on it, it feels real good. I would say Standard for your weight.
JohnnyB said:If you go big , I can guarantee it'll be too soft for ya .
I had the 350 spring and loved it every where except when flat land'n huge jumps or when hitt'n really fast deep g-outs .
The 450 spring helped alot but internal re-valve'n was needed . So I sent in to i-SHOCK to be revalved .
Jovani did for me at no extra cost !!!
I think you may need to give him a call also and ask what he thinks .![]()
dirttrackin280h said:I don't go HUGE at all like most of you guys on here. Mainly little stuff only. If it is too soft, then I will send it into I shock to get serviced. Thanks for the info.
klx110racer said:i had the heavy and im 190 and it was pretty stiff......im getting another f22 here soon and getting the standard.....i hit about 30ft-40 and the heavy was pretty harsh.
