i need the following stuff......if you have it laying around and not using it ill give you some cash for it...im trying to put together my spare part bike so i can have both my fiddies running at the same time.....let a friend take one and mob around.
nut and spring for the rear brake cable....adjusts brake.
rear brake lever return spring.(foot)
kick starter
brake lever and perch.
bolt that holds shifter to the shaft
tank grommets and screws
wire harness
throttle cable for a stock carb but aftermarket billet throttle(sano)
master link for stock chain or gold DID
exhaust nuts at header and
exhaust bolt at rear muffler
screws for the plastics on the tank(phillips)
plastic clips for tank mounts to the plastics
bolts for peg mount(4)
i know i can just go buy all this stuff but im tryin to stay on a budget with this one. any and all help is apreciated.......if you have most of this stuff ill just hook you up with a brand new set of graphics or somthing.........thanks in advance.
kick starter
wire harness
