1 - 10 of 10 Posts
Rear Hand Brake
1 - Perch and Lever (I used a cheap aftermarket one off a quad)
1 - BMX Brake Cable (longer the better)
1 - Metal Hose Clamp
2 - Zip ties
2 – Cable Crimps
Discussion Starter · #2 ·
Step One
Put the perch and lever on the bike and rig up the cable snake the cable along the frame and place one zip tie along the side of the frame where the plastics seprerate the front and rear to hold the line secure
Discussion Starter · #3 ·
Step Two
You are going to need to cut the end of the cable so that there is a plain wire and then strip off some of the outer plastic so that you have more metal cable to work with
Discussion Starter · #4 ·
Step Three
Try to keep the slack to a minumum and you are going to make a loop with the cable and use the cable crimps to keep it looped. This can be tricky because you need to make sure there isn’t to much slack in the cable cause if there is you will have no pulling power.
Discussion Starter · #6 ·
Step Five
Take the metal hose clamp and secure the cable to the swing arm make sure the clamp is very tight so the cable doesn’t move. The clamp must go on the swing arm, if it is not on the swing arm when you sit down and compress the shock it will cause slack in the brake cable and it won’t work.
Note: it takes some playing around with to get it to pull hard. Don’t expect it to be as good as the rear brake pedal but it will definetly work in slowing you down in turns and bringing you down off of wheelies so you don’t fall
1 - 10 of 10 Posts
