how much oil should i put in my klx110 with a clutch kit? and any specific kind of oil?
1 110wannabe · Registered Joined Dec 6, 2009 · 233 Posts Discussion Starter · #1 · Aug 17, 2010 Only show this user how much oil should i put in my klx110 with a clutch kit? and any specific kind of oil?
Paxracing · Registered Joined Mar 23, 2004 · 6,244 Posts #2 · Aug 17, 2010 Only show this user 1 qt 30 wt castrol
1 110wannabe · Registered Joined Dec 6, 2009 · 233 Posts Discussion Starter · #3 · Aug 17, 2010 Only show this user Paxracing said: 1 qt 30 wt castrol Click to expand... thank you!
phatfiddy · Registered Joined Apr 4, 2004 · 2,892 Posts #4 · Aug 17, 2010 Only show this user If it's hot where you live use a petroleum blend 20w 50. Otherwise, use a 10w 40.
S sweetjeep · Registered Joined May 4, 2004 · 921 Posts #5 · Aug 28, 2010 Only show this user I agree with the 1qt, but I disagree with the weight. Use the heaviest you can find. Always. We're not 7 year old 100 lb kids. Don't try to make HP or save $.30 at the expense of your motor.
sandman0407 · Registered Joined Apr 7, 2009 · 481 Posts #6 · Aug 28, 2010 Only show this user 10w40 change it regularly..also depends on how often your riding..1 qt
