1 - 7 of 7 Posts
just recived my manual clutch kit and i have a few questions
1 will my uprated auto cluch springs and plates fit and is it worth swapping them over?
2 anyone know of a fitting guide before i start to try to figure it out for myself
thanks
paul
Not sure about the springs and plates but you shouldnt need them, it should be fine as is. As for installing, very simple, just pay attention to how the stocker comes out and it goes in basically the same. If you have any problems were here to help.
Discussion Starter · #4 ·
right i think i have most of it in correctly but there are a few bits im not sure about!!!!
do part 1 & 2 go together with one of the springs? (5) if so where does the other spring go?
i have now worked out where part 4 goes (the original was still in place :oops: )
i have put a seal in the hole for the kick starter so where does the other one go (3) as it is smaller
someone help please :? :?
Strange, mine only came with one of those springs. But anyways one of those springs goes inside part 1 and then part 2 goes ontop of that and it should slid in and out and spring back. Those will go onto the outside of the clutch basket so that when you actuate the clutch it pushes it toward the crank and allowing it to work properly. Hope that helps some.
1 - 7 of 7 Posts
