Alright the bike came back from powdercoating and im starting in on the build. Im starting this log for anyone wanting to know or do a nsr conversion on there bike. I will start with some pics today and list until the project is finished. Kind of a basic how to....
4-10-07
Bike just came back from powdercoating I went with speedboat sliver and black wrinkle. The speedboat sliver is dull in the shade with no sparkle but in the sun it looks great. You can see in the pictures, 3 of the mods (out of many) you will need to do. The lower triple tree (LTT) needed the stops cut, repositioned, and welded. Also the frame was welded in a few spots and then drilled for the rearsets. I drilled one hole per side using the swingarm bolt as the another hole for the top part of the mount. The top triple tree (TTT) needed to be cut also. I am running the stock zb speedo so the ign holder off the nsr (TTT) needed to be cut for the mounting of the zb speedo. I only had time today before work to get the front end mounted. Also the little black things are spacer for the rear sets to clear the frame.
4-10-07
