1 - 8 of 8 Posts
This seems to be the common set-ups for most.
Under 125lbs - Only (1) HD spring and (1) stock spring, 165cc of 10wt per leg
125 - 175lbs - Only (1) HD spring and (1) stock spring, 165cc of 20wt per leg
175 - 200lbs - Both HD springs, 165cc of 20wt per leg
200lbs + - Both HD springs, 175cc of 30wt per leg
Use this guide as a base-line to get your set-up in the ballpark.
Adjust with springs and oil wt to get it just right for you.
THIS WAS POSTED FROM BBR
1 - 8 of 8 Posts
