1 - 3 of 3 Posts
I tore a 04crf50 to the frame cleaned it up a little and I am going to put it back together but was wondering what people use for lube and grease.
First I’m putting New springs and fork legs in the stock forks. What kind of grease and about how much . Are usually use maxima waterproof marine grease for greasing my axles and what not but I was wondering what I should use for the headset bearings
Any good marine grease will work fine for headset bearings and fork tubes. My favorite is Belray waterproof. Just take a small bit (about a tablespoon) in the palm of your gloved hand and slather the springs liberally, spinning as you put them into the fork uppers to spread the grease.
Discussion Starter #3
That’s what I use on my axles and what not, i just wasn’t sure if a different type was used on the bearings. Thanks
1 - 3 of 3 Posts
