1 - 6 of 6 Posts
If I have stock forks with +1 will the G2 aluminum frame kit with the fox shock and big bike style swinger work correctly?
I have G2 forks here on a RB G2 bike that measure 23" from the top of the tripple to the ctr axle with the bike sitting level. I beilieve your +1 forks measure 21" so you might be a couple inches short in the front? Hope this helps?
Discussion Starter #3
Could I just adjust the shock out and then make do before I can save up and get zokes?
Better yet go with a set of crf 70 forks/clamps they measure out to be 22" and should fit right on. You should be able to pick some up at a reasonable price 100.00/125.00?
Discussion Starter #6
Will the klx 110 forks and triples work? There are a lot more of those than the 70 forks haha
1 - 6 of 6 Posts
