1 - 5 of 5 Posts
So after getting my bike back and starting to break in the new 143 kit im getting some false neutrals. Its mainly in 1st or 2nd gear..What is causing this?? Im waiting to change the oil after this tank of gas.
Answers please! Thanks
It also has the 4th gear drum and a manual clutch kit if that makes a difference
Bent shift fork or maybe not put together right.
Is it in first or second cause the fork work like this one fork is for first and third and the other fork is for second and forth.
do you got the one down three up takegwa drum, because i do and i find a neutral when downshifting from third and have to up shift to get second, anyone else have this problem? 143cc with head cam stroker crank man clutch short shift rod 1dn 3up drum?
Discussion Starter #5
No i have the 4 up drum..Its not happening as much now that my bike is getting broken in so who knows. I'm going to tear it apart tonight and check out the star..might just need a tightening. You might want to check yours out too, its usually the answer to most false neutrals
1 - 5 of 5 Posts
