1 - 20 of 20 Posts
motor swap!
I feel a big bor is the way to go but im not sure what size 8)
yeah my buddy has the hyper 88 kit and mine has 75cc kit . His bike flat outruns my bike no problem and for about 430 bucks you cant beat it
well I'll tell ya' dis mah' buddie gots a stock xr70 and dere be about dree uh us dat gots xr50 wid 82, 85 ,and some 88 big bo'es and we all smoke him uh de line in longa' runs he gots'ta start t'catch down wid de 82 bigbo'e also de 70 wid some bigbo'e gots'ta stait down hall some ass it gots a longa' gear ratio dan fiddy and some betta' haid holla
huh???? :?: :?:
Well I'll tell you this much. My buddy has a stock xr70 and there are about three of us that have xr50 with a 82, 85, and some 88 big bores and we all smoke him on the line, but in longer runs he starts catching the 82 big bores, also the 70 with the some big bores has to strait down hall some ass. Its got a longer gear ratio then the 50 and some better ,,,, i dunno what the haid holla means.
I tried my best anyways.
Jibberish
What is with the Jibber jabber? :?: :?: :D
Hmmmmmmm.. does anyone her speak JIVE? "excuse me stewardess... Um.. I speaka da JIVE." hehehe
Yes the XR70 motor fits in the XR 50 it is the same motor but it has a 72cc piston/cylinder and the bigger vavle head . my susgestion is if you have a XR 70 motor just remove the head and buy yourself a high compression 88cc piston kit (the S stage takagawa piston is too low of a compression ratio for the big head) and get yourself a 20mm carb and a cam and you will be spanking your friends 88's with there stock heads
Hope this helps
Hope this helps
id be looking more towards a 22 or 24mm carb
I agree a 22mm or 24mm carb will work but it makes the motor run a little fat and you don't get the snap like the 20mm carb. leaner is better for mid and top end power .
But this depends on the weather now that it is getting cooler there is more oxygen in the air so you have to rejet your carb or you will spitting flames out your tail pipe and toasting your exhuast valve
Hey XRracer when is your new site going to be up?
BIGGER CARBS AND OTHER MODS
HEY,
STOCK CARB, PROPERLY JETTED IS GOOD UP TO 88CC LITE BORE
STOCK HEAD NO HEAD MOD. RIGHT GEARING ON SPROCKETS.
18MM IS OK PROPERLY JETTED ON 88CC LITE BORE STOCK AND WITH
HEAD MODS LITE PORTING, AFTER MARKET HEAD (BIGGER VALVES)
18MM GETS GOOD LOW END TO MIDRANGE CHOOSE A GOOD CAM.
DONT GO ABOVE A R.V. OR TOURING CAM.
20 MM CARB, PROPERLY JETTED IS GOOD ON 88CC PORTED HEAD,
MATCHED INTAKE, OR AFTER MARKET HEAD, TOURING CAM, 20MM INTAKE(SAME DIAMETER ON BOTH ENDS). RIGHT GEARING ON
SPROCKETS 15/37 OR 15/38 PULLS GOOD ALL THE WAY THOUGH.
22 OR 24MM 88CC EXTREME MODS INTAKE AND BIG VALVE HEAD
TOURING OR RACE CAM MID TO TOP END PULLS HARD UP TOP
22 OR 24MM CARB PROPERLY JETTED, SUPER HEAD, RIGHT CAM
COMBO AWSOME POWER ALL THE WAY THROUGH TO THE TOP PULLS
HARD (HANG ON NO KIDDING!!!) RIGHT GEARING
GOOD MOD (CLASSIC HONDA SUPER CLUTCH) 139.00
AWSOME MOD ( CLASSIC HONDA 3 SPEED GEAR CHANGE) "CHANGES
YOUR FIRST GEAR SO YOU CAN USE IT A LITTLE TALLER, SECOND GEAR
STAYS THE SAME, AND THIRD IS A LITTLE TALLER MORE TOP END"
I RECOMEND IT . BIG DIFFERENCE ON 88CC UP..... 215.00
DONT GO WITH A 5 SPEED TRANNY ITS OVERKILL !!! FIDDIE TRACKS
ARE NOT THAT LONG THERE TIGHT SHORT STRAIGHTS,
3 SPEED AUTO OR CLUTCH SETUP IS THE BEST THE RIGHT GEAR IS THE
KEY. A CLUTCH SET UP IS GOOD OFF THE LINE, AN ADVANTAGE THE DRIVE OUT OF THE CORNERS IS KEY... CORNERS ARE THE KEY IN AND OUT AS FAST AND SMOOTH AS POSSIBLE...... AN ART!!!!
5 SPEED ON THE STREET OR ON SOME TOTALLY SICK TRICKED OUT
OUT OF CONTROL 124CC TWIN CAM "ONLY ROCKIFFELER CAN AFFORD"
ALL KINDS OF MENTAL OUTLAW BIKE GET THE PICTURE!!!!
THANKS FOR READING AND YOU TIME OLDSCHOOL
1 - 20 of 20 Posts
