When I pull in the manual clutch on my Xtreme 107 the engine dies out. This happens in neutral or when moving and changing gears. The only way to keep it from dying is to rev the engine while shifting. Once in gear and moving the engine runs fine at least until the next shift and the clutch is pulled in. The idle is set properly. The clutch does not seem to be slipping.
Any suggestions?
Any suggestions?
