1 - 4 of 4 Posts
I run it for 10 or 15 minutes (easy), then let it cool . repeat 2 more times, then the first hour after that take it easy you can put a load on it but don't take it to too high of RPM's.
start the engine up to make sure there aren't any leaks. keep at high idle (not with the choke). As soon as you feel temp in the cases. Ride it like you stole it. You have to develop enough cylinder pressure to seat the rings and putting around doesn't do that. Change the oil after about an hour of riding.
1 - 4 of 4 Posts
