1 - 4 of 4 Posts
Ok, I have the TB stock head 88cc kit now. I was just wondering if I can run a E22 head with this setup. Do I really need a new piston because the TB one is a semi dome and is already like 13/1 compression. Also, would the cam that came with the TB kit work in the E22 head??
The cam should work, not sure whether or not the head will work with the piston thats in it now or not. You could email Mike at TrailBikes and ask him or see if you can get the piston for his race head to try with the E22 and that will probably work since it has a slightly bigger dome to go with the bigger dome of the race head and the E22.
1 - 4 of 4 Posts
