Has anyone done this? Im thinking it would give me more snap. I need some tips. Thanks
phatfiddy said:Don't drill the cam sprocket. However, you can elongate the holes on your ignition pickup to advance timing. This, along with flywheel lightening will give your bike more 'snap'.. Revs will climb quicker if you have about 8-9 oz. removed from your flywheel![]()
firepower354 said:You're talking cam advancing, not ignition. Both can help bottom end, hurt top.
Rest of the combo?
Rest of the combo?
phatfiddy said:Ditch the e22 and get a new trailbikes race head.. Lots of bang for your buck and it's and easy bolt on.. Jmo
geezer said:If youre running a stock cam its a waist of time.Send out the head for porting to someone that knows what thier doing and get a bigger cam and springs. Or just buy a 140 and be done with it.
ItsBrett_205 said:Im running a 88 kit with a E22 head, and a 20mm carb. If thats what your asking. What do you think I should do?
firepower354 said:Porting the head and manifold(pref the Tak long & low job), and stiffer valve springs will give a good all-around torque curve. Make sure you've got a tight piston to head clearance, .030" or so. A cam is OK, if you have a closer ratio trans, but the stock 5.25/5.5mm one is pretty nice overall. Add a YX 160-type outer rotor kit for better throttle response. Retard mod on the flywheel, since too much timing makes them snappy off idle, lay down up top. Racers run up top![]()
ItsBrett_205 said:could I shim the vavle springs to make them a little stiffer?
