1 - 3 of 3 Posts
Does anyone know if the clutch, crank, and head of of an xtreme 107 work in a xr50 motor?
Thanks in advance,
Tyler
the clutch will work if you use the xtreme's clutch cover. The crank will only work if you use the longer cylinders, 69mm deck height. The crank is a long rod crank. The head will work with the flat top pistons.
Discussion Starter · #3 ·
THANKS!!!!!
1 - 3 of 3 Posts
